Originally posted by trillian
View Post
Optipower Backup Guard
I don't think it will work with LiPo very well. With LiFe, I had to wait for the voltage to drop at settle at 6.6 before flying, otherwise it would alarm in flightHarry
Powered by Futaba 18SZ
I bought a early version which played up with my life pack so Andy put new firmware onto it for me...problem sorted. I have just put a new one on a setup with 2s lipo for the rx and contacted Andy before I bought it to
see about the firmware issues on the early units. His e-mail back to me confirmed that the later units are no problem with lipo or life batteries..Regards Adrian
I AM SPARTAN V4 + Spirit---TT--RAPTOR-E820 x 2-E755-E700--SYNERGY-E7SE--ALIGN-600PRO
--... ...-- neXt
A few bits and bobs & a few electric gizmos to stir the air.
I wonder how to tell if it's the earlier version, I have a feeling the ones I have are not the latest.Originally posted by 10x View PostI bought a early version which played up with my life pack so Andy put new firmware onto it for me...problem sorted. I have just put a new one on a setup with 2s lipo for the rx and contacted Andy before I bought it to
see about the firmware issues on the early units. His e-mail back to me confirmed that the later units are no problem with lipo or life batteries..Kasama, Minicopter, Henseleit, JR, Shape, Beam
Proud recipient of 7 EGS!
and a platinum star
Initially I had one of the older UG with the old firmware... The old ones had the white LED light wires soldered on the circuit board. The ones with the newer firmware had a socket on the board in which you can plug in the white LED lights. I read that there is an even later version that allowed firmware to be programmed in the board without the need to send it back.
Hmm, might investigate having mine sent off for firmware updates...Harry
The latest UG I bought has a micro USB socket on the top right corner....Regards Adrian
--... ...-- neXt
Neither of these have a micro usb socket but the one with the external LED does have a little connector attaching the LED lead, it's not hard-wired on. So maybe I'll just try it and see what happens.Originally posted by 10x View PostThe latest UG I bought has a micro USB socket on the top right corner....Kasama, Minicopter, Henseleit, JR, Shape, Beam
and a platinum star
If it helps, the update for the RX Lipo/LiFe handling was available from around early May this year, so if you bought before then it will probably need an update.
Even after then there was undoubtedly older stock still in the retail channel for a while.
Looks like Ultra Guard will have a brother shortly to protect your BEC and model....
Optipower - OPTIPOWER BEC GUARDRegards Adrian
--... ...-- neXt
Could anybody tell me how to charge the lipo on my Optiguard, using a PL6 and a standard balance board, (not MPA) so i can charge from balance lead only.
The pack hasn't been used for a while, so i need to put some juice into it before going out flying.
I have read a previous post saying i have to change the settings to FMA on the PL6, but i don't know how to do this.
Thanks,
Dan.Last edited by Dan22; 29-12-2014, 10:04 AM.
TREX 550X - Beastx HD Pro
GOBLIN 570 - V-Bar Neo Pro
Taranis X9D Plus
neXt Sim
AccruRc Sim
Proud wearer of 3 X EGS
Thanks MarkOriginally posted by Mark_T View PostI'm not sure that you can do a balance wires only charge with a PL6, using a standard FMA balance board, that is a feature of the PL8 which they didn't put on the PL6.
How low is the pack anyway?
The pack is flashing red but after 5 flights it hasn't got sufficient charge to hold its own after flight pack is removed.
I think its faulty as it won't register on my lipo checker!
Dan.
Taranis X9D Plus
neXt Sim
AccruRc Sim
Yes, standard 2s that comes with optiguard, my other bug registers on the checker so the lipo must be goosed.Originally posted by Mark_T View PostIt is just a normal 2S pack, so as long as your checker works with 2S then it should show up OK.
I will try another 2s battery to make sure the rest of the optiguard still works.
Thanks,
Dan.
Taranis X9D Plus
neXt Sim
AccruRc Sim
