You will still need to use a CellPro 6S board in the middle as you can't connect that Parallel board direct to the 10S, but hopefully you already knew that
Edit: Also under the heading of 'you probably already know this'
That charger is only really going to handle 3 of those packs at 1C and then only if you are feeding it with the maximum voltage it can handle (16V)
It is not the greatest solution for charging multiple packs.
