Just thought Id share my initial experience with my new forza 450 kit I purchase with motor esc and servos!
i also got some align 360 blades and some gens ace 2200mah 60c lipos which are a perfect fit :)
This is my first new build kit and took a mere 2 hours to build,and another hour to run the electronics, mount an msh brain and set it up.
first spool up I needed to track the blades and switch from sport to 3d setting in the brain!
wow- easy as pie! Rebuilding some second hand helis I have has been a real task but this is one of the easiest helis to build and there are hardly any parts to it!
The heli flies superb and due to the easy setup procedure with the unique swash tool and servo horns it needed no trimming.
i flew 4 lipos and ended up tuning throttle curves to
n- 0-40-75-75-75
1-80 flat
2-90 flat
theres loads and loads of power on tap for me and for £148 for the combo plus the brain this is a superb bit of kit if recommend to anyone!
even the carry bag for £37 is fantastic quality!
I hope this helps anyone looking into the forza 450.
n- 0-40-75-75-75
1-80 flat
2-90 flat
