Is there a trick to this? Seems to take me ages to get the front posts into the grommets..usually ending up feeling through the hole with a thin rod and levering the post over the inner grommet flange...
fitting the canopy
[quote=pgkevet;619324]Is there a trick to this? Seems to take me ages to get the front posts into the grommets..usually ending up feeling through the hole with a thin rod and levering the post over the inner grommet flange...[/quote]
I haven't quite found the trick to it yet myself. Sometimes I luck out and it goes right on and other times I am trying to line up one of the front grommets, usually the right side one but maybe that's due to some habit of the order I do it in.Kasama, Minicopter, Henseleit, JR, Shape, Beam
Proud recipient of 7 EGS!
and a platinum star
U just get used to putting it on. I used to pull the bottom of the canopy apart and use my fingers to help locate. Really easy, no mods needed.James
SEMAS Flying Club
