Me raptor has developed a bad case of the shakes , ive checked n balanced blades , what else should i be checking please ?
Raptor 30
Have you crashed it? Heavy landings?
Feathering shaft?. Is the motor running ok? It could need tuning to suit the weather.
Headspeed low?
Blades correct tension in the grips?
Mainshaft bent?
Is this at all throttle positions?Last edited by David Drew; 16-04-2014, 05:22 PM.Happy Landings.
David
Raptor 50. OS50
Mcpx
Blade 130x
Goblin 500
Bent flybar.
Bearings goosed.The Fleet
Trex 450 Pro on Brain 2
Mini Titan super Cobra ah1
Alien 550 Quad.3DR Pixhawk
Futaba 7C 8FGS 14SG
Specktrum DX6i
Flybar straight , blades in grip so i can nudge them forward they not loose , fine on ground , soon as it gets in the air starts shakin violently , front starter shaft bearings bin changed everything tight checked and double checkedRaptor 50 , raptor 30 , eflite blade 500 3d, blade 450 3d, spektrum dx7s,
hitec eclipse pro 7 tx with optima receivers
Blade 130x with lynx upgrades
raptor 90 under construction
You need someone to tacho it for you.Originally posted by martin uly View PostThe motor sounds like its going at right rate of knots , how do i know what head speed its running please
if it is not headspeed then something is bent or loose in the head or mast.
Are the paddles in line with the flybar carrier?
Failing all that you need someone to take a look.Happy Landings.
David
Raptor 50. OS50
Mcpx
Blade 130x
Goblin 500
Paddles are in line , the more throttle you give it the more it shakes, have given it good look over and carnt see owt loose, bit of a mystery lol , will get someone to check it over me thinksRaptor 50 , raptor 30 , eflite blade 500 3d, blade 450 3d, spektrum dx7s,
I use this app for checking headspeed https://play.google.com/store/apps/d....headspeedtach.
Ive not compared it against a dedicated tacho but calculated headspeeds have been very accurate and its free.
Just spotted this...look for the post on head dampers
http://rc.runryder.com/helicopter/t84768p1/Last edited by PKNEC; 18-04-2014, 10:39 AM.The Fleet
Futaba 7C 8FGS 14SG
Specktrum DX6i
