Align 325mm blade problems
  • Align 325mm blade problems
    Has anyone else used Align 325mm blades on their mini titan. As soon as I ut them on i had flight problems and didnt realise it was the blades at the time. Since going back to the origional woodies, no more problems.
    whats the problems. bit more info
      i think its probably the blade tracking is out??
        wont necessarily be the blades then... i have found there much better than the stock MT ones mind.
        Lee
        Lee
        www.raptoruas.co.uk
        www.lee.rcha-uk.com
        www.gensace.de
          Are they the 325 Pro blades or carbon?
          sigpicx2
          Airskipper 50 - For sale
            For a wooden blade the 325 Pro's pee on most of the others available IMHO of course
            Phil
              Mark
              sigpicx2
                Thank god for that, there the one's I've brought for my 450, (red colour).
                sigpicWayne AKA OB1
                Plus 3 Eddie Gold Stars, yay!
                  I really like the Align pro blades too, 325 on my 450 SE and 315 on my 450x.
                  They are well made, balanced and quite durable, I had 2 crashes with my 450x and the blades were unmarked.
                  They give a similar feel and stable flight characteristics as CF blades, but cost only £9 a pair!
                  regards
                  Pip
                    I had them well tracked but got a lot of tail wag. Had a lot of vibration too until i went back to the woodies. The blades were Align fibre blades.
                      The Align fibre blades are not the best and do have a reputation for tracking issues.
                      I had problems with mine until I smashed them in a crash.
                      The PRO blades however are very good and my 450 XL was never smoother.
                      sigpicx2
                        Magic!
                        sigpicWayne AKA OB1
                          Well, everything is finally setup, trached, alighned. Flying really well. Might brave a circuit soon !!
                          Cheers for the replies.
                            Tracking & Shaking
                            I fitted Align blades and the performance was far better than the stock blades. After several hard flights the tracking went out and stayed out what-ever I did to try to cure it. A different set of carbons made no difference.
                            The final fix was to fit the Raptor metal upgraded metal blade holders (PV0803) and mixing levers (PV0805). These come complete with all bearings balls and screws plus a big dent in the bank account.
                            NO MORE TRACKING ISSUES.
                            HOWEVER - After a few minutes flight the skids started to shake violently. If I put the model down, spool down and take off again the shaking stops but then starts again after a few minutes flying.
                            I have my main blades stiff in the holders but not excessively tight.
                            Any clues anybody
                              I thought we were talking Mini Titan here not Raptor??? Anyways Flyaheli check your feathering spindle and tail shaft arnt bent mate. This normally contributes/causes symptoms like what your saying.
                              Lee
                              Lee
                              www.raptoruas.co.uk
                              www.lee.rcha-uk.com
                              www.gensace.de
