Lateral play in tail grips
  • Lateral play in tail grips
    Should there be any? If I pull on mine, there is about 0.5mm of play I guess, in each blade grip. Should this be there? Not sure if it was when I built it. When it came from the factory it was all fully assembled, I have tried to dissassemble it but it refused to come apart, so just re tightened and forgot about it! Not flown for three weeks and little things are bugging me now!
    Synergy N5 -BeastX
    450 Pro -BeastX
    Black Horse Sukhoi 31
    DSX9
    Eagle RC Heli Club
    It maybe has thrust bearings in it. They will be rock solid when the tail has spooled up
    Del
    Climb-Out
    3D Scotland
    Proud owner of 2 EGS
      Hi,
      A small amount of 'Float' is perfectly acceptable as once the tail assembly is spinning the thrust races will take up the load.
      I will check mine when i get home and let you know, but i'm 99.9% sure they are the same.
      Thanks!
      Rossco
      Equipment for Sale:
        My Vision 50 is the same, as is snowy's. They're fine once spooled up
        Harry
        Powered by Futaba 18SZ
          Mine has no lateral movement at all. There is a tiny amount of sideways movement, but nothing worth worrying about.
          Most tails I've had do have a little end float, but this will be taken care of by the thrust races when spooled up.
          Ian
          Knight 3D
          Velocity 50
            Ta muchly, I get paranoid about little things if I don't fly for a while!!
            Synergy N5 -BeastX
            450 Pro -BeastX
            DSX9
            Eagle RC Heli Club
