On my kit the tail is pretty much assembled form the factory. The tail pitch slider seems to be pretty tight on the output shaft with some parts feeling notchy.
I had this on my Raptor once and found it was down to too much pressure being put on the brass sleeve. However on the N5 setup I can only see 2 things that could possible to this:-
a) The starlock washer
b) the pivot ball.
Does anyone have any suggestions before I embark on a strip down and reassemble?
Many thanks
D.
b) the pivot ball.
Many thanks
D.
remember to do the bolts that are inside the tail gearbox that screw in to the metal piece for the tail pitch bellcrank - the only way to get to them is to fully disassemble.
