Helical Pinion Height Setup To Prevent Helical Forces
  • Helical Pinion Height Setup To Prevent Helical Forces
    This is just a tip for setting the Helical Pinion Height To Prevent Helical Forces.
    Helical Pinion Height Setup:
    On the E6/7 the bottom of the pinion should be in contact with the lower shaft support bearing. If it is not set up this way the helical forces will pull down on the shaft. Setting your helical pinion height correctly and you will not have an issue. Matt designed it to cancel out helical forces.
    I have added this tip to my Tips & Tricks Thread here: http://www.rcheliaddict.co.uk/synergy-e6/65430-synergy-e6-7-tips-tricks.html
    Thanks!
    Rossco
    Equipment for Sale:
    Pics would help exactly what you mean if possible.
    Troll buster
      Picture Added
      Thanks!
      Rossco
      Equipment for Sale:
