The long awaited Synergy E7 is finally here! Kits are rolling through customs right now and will be in transit to your local hobby shop next week! The Synergy E7 is an ultra light, ultra rigid, 700 class helicopter which was designed with high efficiency and long flight times in mind. That’s right, low weight means longer flight times! With ultra low weight, your disk loading is low which means your motor works less, your servos work less, and your entire helicopter is happy!
The 116T Machined Helical Main gear is whisper quiet and efficiently transfers power from the motor to the rotor disk. This machined main gear has been thoroughly tested to withstand the extreme power of today’s electric systems. The pinion to main gear mesh is fully adjustable with four different gear ratios to choose from. Pinions included in the kit are 14 and 15 tooth pinions. Optional pinions are 12 and 13T. Here at Synergy we believe in letting modelers be modelers, you can configure the E7 how you want to, not how a pro pilot, a designer, or an owner of the company thinks it should be done. You are in complete control. Use this power wisely!
That’s not all! When you purchase the E7, you also get everything you need to configure this model as a 600 class model. This includes, extra belt, boom, tail push rod, boom supports, as well as blade bolts and blade bolt adapters! That’s right! You get to choose your own adventure and build what you like! When configured as a 10S E6, your total flying weight will still be right along side all of the other 600 class electrics on the market today.
I hope you enjoy the Synergy E7 (or E6 if you may)
Your friendly Heli Designer,
Matt Botos
Features:
Matt Botos
Features:
- Precision machined helical main gear
- Third bearing block support for main shaft
- Bearing block support for motor pinion
- Multiple battery configuration options (8s, 10s, 12s)
- Flybarless head designed specially for ALL of today’s FBL Electronics
- Extremely light and Ultra rigid carbon fiber frame design for those serious competition pilots
- Motor mount designed for 30mm mount spacing
- Motors up to 60mm in diameter accepted between frames
- Accepts rotor blades 600-690mm
- Carbon servo arms provide for a much better precision feel in flight
- 14-15T Pinions included (12-13T Optional Pinions)
- Fully adjustable gear mesh
x 3
