NEW Synergy E6 Pictures & Details:
This is your next 600 size electric helicopter! Designed by Matt Botos who was one of the first professional pilots in the USA to utilize flybarless technology with electric helicopters. Matt’s knowledge and expertise were poured into the E6 design with absolutely no exceptions in quality and performance. The E6 is light and agile while maintaining a rugged frame structure to handle that unfortunate impact with the dirt. The E6 has the presence in the air of a 700 size helicopter in an ultra efficient 600 size package.
Precision Machined Helical Main Gear-
Smooth running Mod 1 custom machined helical gear is stealthy silent and provides plenty of girth for todays high powered electric motors. Settling for a molded main gear on a high powered electric was just not an option.
Third Bearing Block Main Shaft Support-
The main shaft has third bearing block support to ensure proper gear mesh and eliminate frame flexing during hard 3D maneuvers.
Motor Shaft Pinion Support-
The E6 pinion is supported by a lower bearing block which also ensures a proper gear mesh.
Carbon Servo Arms-
Custom carbon servo arms for the ultimate precision in flight.
Features:
e6_third_bearing_block.jpge6_pinion_support.jpge6_overall.jpge6_front.jpge6_carbon_servo_arm.jpge6_machined_helical_main.jpg
Synergy E6 Sneak Preview! : Synergy R/C Helicopters – The Official Website
Looks Awesome!!, been considering a new electric machine for easy plug and go flights after work!!
Carbon Servo Arms-
Features:
- Precision machined helical main gear
- Third bearing block support for main shaft
- Bearing block support for motor pinion
- Multiple battery configuration options (8s, 10s, 12s)
- Flybarless head designed specially for ALL of todays FBL Electronics
- Extremely light and Ultra rigid carbon fiber frame design for those serious competition pilots
- Motor mount handles 25mm or 30mm mounting patterns
- Motors up to 60mm in diameter accepted between frames
- Accepts rotor blades 600-630mm
- Carbon servo arms provide for a much better precision feel in flight
- Pinions included!
