Is bleeding awesome :) downwind , she's a rocket , only the first flight too :)
Goblin 500 maiden in 40mph winds
Just try and keep it in one piece for now ;)sigpic
Goblin 500 SK540 jive 100lv
HD 500 SK540 jive 80 lv
Oxy 3 SK540 minijazz20
Good news dude :) 2 flights and she's still complete . Now going home cos it's blooming chilly :) will return tomorrow with 520 mains , cos the scorpion 4025-1100 on the 18t pinnie ain't spinning fast enough , my pyro 600-12 will be here next week :) oh yeah , happy days :)Seaking
I had to put a 19t on the motor to get the head speed at 2600 and I love it, probably more than my Goblin 700 :-)Phil
Align MR25 Racing Quad
I know, after the logo 550sx are you sure this was a wise choice ade?sigpic
I did the extra bearing mod and no issues since ;)sigpic
But they still explode when they hit the ground. That's why I sold mine. I've done away with 550 machines and got the x4ii which is much better at crashing.sigpic
[QUOTE=heathy;1086481]But they still explode when they hit the ground. That's why I sold mine. I've done away with 550 machines and got the x4ii which is much better at crashing.[/QUOTE]
dude , I didn't give gaui a thought :( I'll look up the x4ii , if it's light , can run 520's ish n my incoming pyro ? Hmmmmm bugger , another spanner in the works :)
adySeaking
Ady. 473's are the biggest blades it can swing in stock format. Can be stretched with a X5 boom to swing those though.sigpic
Cool , when I can get on a pc ( phone at the mo ) I 'll look them up , is the x5 just an x4ii but bigger ? Will do some research , my fav and most cost effective set up is around 500-520 blades n 4000 ish packs , awesome , cheers :)Seaking
X4ii and x5 are completely different frame designs. If like me you crash lots then the x4 is the better choice as it has separate lower frames. The X4ii can take upto 5000 packs but is best around 3500. The X5 I think is good around 4300. Both are cheap to crash.
My last was full power on its side without hold for a split second as I was too low
Caused £140 including canopy and edge 473mm blades.sigpic
