Oh god what have I done...
  • Originally posted by trillian View Post
    With the Kontronik you can build it as light as possible because all you need is a small buffer pack or an Opti Ultra guard.
    Just out of curiousity though, I wonder what is the max main blade size you can run on the 635? Also, if it uses the same grips as the 700 it would have a 5mm blade bolt and all the 600 size blades I am familiar with have 4mm bolt holes.
    I once had a pair of SAB 660mm blades with a 5mm hole.
    Yeah I'm intending to run a small buffer pack, although I'm assuming it'll never really be needed as the Kontroniks sound bullet proof. Plus with my auto skills it probably wont matter if I have control or not :lol:
    It can run up to 640mm blades I think, and yes it's the same head so has the 700 grips with 5mm bolts. The only ones that fit as far as I know are Radix 625's ( as you can press the metal spacer out to get 5mm holes ) or SAB 630mm blades as the Goblin also has 5mm bolts on the grips.
    Lynx Heli Team Pilot
