On the amendment sheet to the manual it says to use some washers to take the slop out of the flybar cage, it incorrectly states them at being 2mm when if I have identified the correct ones they are actually about 0.25mm each.
Without these washers fitted there is infact slop but im finding with them the flybar cage is too tight and doesnt seesaw very freely at all. If I use just one of the washers I still have a very small amount of slop.
Whats the solution? Do I need to source some 0.20mm washers or something?
thanks.
thanks.
