As we all know the (only!) problem with the 550SX is the limited choice of motors, and it's a question that comes up fairly often, so I've been doing a bit of digging online and with manufacturers to see if we could try and have a definitive list of what motors work. As it happens we now have more choice than we all thought
For the uninitiated... In stock form the 550SX needs a motor with 30mm M4 mount spacing and a 5mm shaft, of which the only one is the stock Scorpion 4025 - 1100 (I know you can get the 25mm motor mount but then you can't use the counter-bearing and 3rd bearing support, and it isn't in production so it isn't really a future proof solution). This motor is OK, but there are many that don't like Scorpion motors.
The good news is that there are an increasing amount of motors that are coming with both 25/30mm mount spacing and 6mm shaft. So if we mod the drivetrain to use the Logo 600SX Mod1 gear and pinions we can use these motors, as seen in the linked doc. Pyro 650-103L, 550SX Edition.pdf
Anyway, here are the options:
In stock form:
Mikado branded Scorpion 4025-1100
Mikado branded Scorpion 4020-1100 (as sold with older 500 kit)
With Mod1 gear mod
Kontronik Pyro 650-103L (AWESOME but ££) link
KDE Direct 550XF-1200-G3 (NEW - anyone tried this?) link
KDE Direct 600XF-1100 (Not sure it is available in the UK)
Scorpion Branded 4025-1100 (produced after April 2014)
Align 730MX (with 14/15t Mod1 pinion)
**Xnova 4025-1120KV (coming soon!)
**coming soon from XNOVA! I have just received this response:
Xnova 4025-1120KV 1.5Y - SHAFT A (link)
Hopefully this helps someone, if I've missed anything then let me know.
Phil
In stock form:
With Mod1 gear mod
"We will offer from now the 4025 size, which is perfect for logo 500 or 550 with the
new mounting option, it means 2* M4 *30mm and 2* M4 25mm"
So from the next shipment from Xnova the below motor will fit!new mounting option, it means 2* M4 *30mm and 2* M4 25mm"
Phil
