Beast unbound itself! Won't rebind
  • Beast unbound itself! Won't rebind
    Hi all, I have flown my 450X about 15-20 times since new. All was great. Today I flew one battery pack was fine, I changed battery for a second flight... BeastX failed to connect to my Dx7 and started to scroll though the N-H LEDs (which I believe is no tx connection) I tried to unplug and plug the battery maybe a dozen times, still nothing. I had a bind plug so I tried to rebind, now the Ar7200Bx won't bind to my tx. And this beautiful no wind day has gone to waste while I had 5 charged batteries waiting in my bag.
    Ive read about people having similar issues but usually (from what I've read) it was a new beastX and it never bound in the first place.. Mine Was bound for 2 weeks and now all of a sudden it's not talking to my tx anymore.
    My trims are neutral. Throttle is down all the way
    i held my tx right up against the Rx while trying to rebind
    i stood 5 feet away trying to bind
    I unplugged servos while trying to bind
    My tx works with my other models (I tried today after this issue with 450x)
    Anyone had this problem? Or know a fix?
    Welcome to the heliaddict forum
    When they do this the advise is generally "It knackered send it back". A good one should never do this.
      Sorry. Never heard of this before myself with an AR7200BX. If your TX works with other models, then it does indeed seem like an issue with the BX.
        You may find that moving the tx well away from the model (10 ft) and raising the heli off the ground helps. I sometimes find my AR7200bx doesn't connect on the first try, probably due to the way I have the aerials orientated. If the model is sat on wet grass or near a large metal object, that can sometimes prevent connection too.
        Blade 180 CFX - Stock setup
        Gaui X3 - Spartan VX1e, 460MX, Savox
        Goblin 500 - Spartan VX1e, eFlite 550H, BLS153, Xpert SI2201, HW100
        Hughes 300 - HK450
        AS350 - Blade 500X
        BO-105 - TRex 500 Dominator
        Bell 222 - Stretched Gaui X5 mechanics
        Jetranger - Stretched X50e mechanics
        Airwolf - Roban 800
          Re: Beast unbound itself! Won't rebind
          Mines done this once had to get it sent back and was replaced with a new one.
          Gaui X5 - Spartan Vortex
            Thanks for the replies.
            I'm going to call horizon today once they are open. I guess I'm going to have to set the beast up myself when It comes in. Is setup difficult to do? I'm new to helis, the 450x was my first heli so I'm pretty p'd off that it petered on me.
            Damn horizon. $500 paper weight for a few weeks now till I get a replacement.
              mate usually this happens in between days, received one day, checked, returned the next - never waited more than 3 days on them to have the new part to hand
              Sev
              Thunder Tiger E700 BD3SX
              Trex 450L DFC BD3SX
              Trex 150 PRO DFC
              Blade Nano CP X
              Blade mCP X v2
              Blade 130X
              DJI Inspire 1
              DJI Phantom 2 iOSDmini
              EMAX 250 Pro V2 FPV Racer
              Futaba 18MZ
              MK Heli Club MKMAA
              Proud Owner of:
                Try as said above and re bind with tx further away. And keep away from metal objects.
                Gaui x7 lush
                Gobbalin 500
                ALL ON SPEKKY GEAR
                Blade 130x2
                nano
                  Just now I tried again, from 5 feet, 10 feet, right up close. Ridiculous
                  I was able to bind to another Rx right away. Tried the beast again - nothing. Just blinks the one LED fast showing it in bind mode.
                    Can u do a factory reset ?
                      I don't really know how to set up the beast after I reset all the settings. I am new to helis, flown rc planes for 8 years but only about 3 weeks flying helis. They are waaaay more complex to fly and setup. There is literally no set up with planes I even build my own foamy planes and the only setup required is centre the servos and trim haha.
                      I've officially switched over to the helo side. I will learn this stuff but I was hoping to get more flight time before having to do a full setup on a flybarless system I have no clue where to begin.
                      Anyone else think a factory reset will fix this?
                        Have heard of similar things before so try a new model set up on tx. Just wright all your current tx settings down then copy onto new model.
                        Gaui x7 lush
                        Gobbalin 500
                        ALL ON SPEKKY GEAR
                        Blade 130x2
                        nano
                          I copied the 450x settings into a new model memory. Didn't work. I tried a completely new model mem from scratch, also didn't work.
                            Send it back. U will get a new 1. No quibble.
                            Gaui x7 lush
                            Gobbalin 500
                            ALL ON SPEKKY GEAR
                            Blade 130x2
                            nano
                              Hi guys thanks for all your suggestions. I FINALLY got my BeastX back today! I sent it in May 6th ! not sure how "R4NDOM" got his back in 3 days turn around, but anyways it turned out to be a faulty Receiver RF board, it needed to be replaced. I bound the bird back to my Rx and all seems to be working again. Will fly it tomorrow.
