about to buy a 130x but......
  • #31
    If your gonna use standard frame I would use a stiffener for motor base plate. Or buy an extreame frame and no modding. And as said above 8000 kv 11 tooth with standard frame or 10 if you want a little more flight time but you will have to mod ele servo a little or use an extreame frame.
    Gaui x7 lush
    Gobbalin 500
    ALL ON SPEKKY GEAR
    Blade 130x2
    nano
    • #32
      Re: about to buy a 130x but......
      Just done that & got the xtreme frame, arrived yesterday so will be building today
      Goblin 500
      | Blade 130x | Blade 180cfx
      Spektrum DX8
      GWR Pilot 2011 & 2012
      • #33
        If the 3in 1 is very tight like mine was, which caused vibes. You will have to file the area a little where the frame clamps the 3in1. But that took about 10 mins and now works a treat.
        Gaui x7 lush
        Gobbalin 500
        ALL ON SPEKKY GEAR
        Blade 130x2
        nano
        • #34
          Wow that's a lot more power than the hp08... I was also wondering about the HP10...
          with your spin do you use standard stock like lipos? The frame upgrade sounds good, but you can get by without it with the spin? I was going to get the MH frame upgrade for the BL mcpX what to do first ;-)
          Oxy 2, 180cfx, 130X
          Goosky S1
          DX 8 , Phoenix sim, DJI P3P
          • #35
            Yup & also use Overlander 360mah & Gensace 450mah
            Yup you can get by without the new frame, I have for a few flights but saw that uou have a move able motor mount whuch helps meshing the motor
            Goblin 500
            Spektrum DX8
