Hi all i just rebuilt my whole tail stock except pitch slider extreme one and lynx tail grips and i now get random tail wag it generally happens when i put tail inputs to the heli or when first spinning up. Same thing i suposse as heli is correcting just wondered if you had any ideas how to solve it. I'm on -7 gain already as it was much worse with the gain turned up
Random tail wag
have you tried gain from lowest setting working upwards that's how i did mine but the wag was present most of the time.Today's outlook is fine for flying.- Spektrum DX18 gen2, Phoenix Sims, Align MR25XP.
- Flickr Through My Pictures.
Random tail wag
I had a random violent tail wag caused by a twitchy tail servo today, a quick squirt of contact cleaner and its as good as new
DX8
Phoenix
RealFlight 7
Mcpx BL
Trex 550 DFC with Vx1n
Trex 700 DFC Pro Hv with Vx1n
Zmr250 mini H Quad racer
if its only on start up try spooling up a bit slower, as the massive amount of torque on start will indeed spin the heli, and there is no way the tail rotor will be at an efficient rpm to copeCurrent Heli's, Align Trex 550, Blade MCPx BL, Blade 130x, Blade 450x, JR DSX9
Hi all
I am new on here but not to heli flying.
I recently bought a 130x, fantastic peice of kit, but after a small tail first incident, the tail starting violently shaking and I found I had stripped a tooth from the tail drive gear on the main shaft. I have replaced it with the metal upgrade option and while I was at it, did the bearing upgrade with a kit from RC-Hero.
Since doing this I cannot get rid of the violent shaking. This is no small oscillation, it's almost unflyable.
I have spent 3 days trying to get rid of this since. I have the gyro down -3. The tail boom is not broken. I have changed to the spare tail gears just in case. I have tried tightening and losing the tail blade grips.
At a loss to explain it. Any ideas?
Also, if I need to clean the tail gyro with contact cleaner, are we talking the plug here or something on the servo itself?
here's a video of someone cleaning a mcpx servo, same kind of thing for the 130x. (skip to 2:45)
Blade mCPx Servo Cleaning - YouTube
Nvkiller, your tail servo may have moved slightly. You could try moving it closer to the tail or further away. I found that sometime causes wag or reduced tail control.Paz
Goblin Black Nitro
Goblin 380
Oxy 2
Vcontrol
Leicester Heli Flyers Club
Thanks to this post and video, my 130x is flying like a dream. Thanks to all that posted.Originally posted by n00by View Posthere's a video of someone cleaning a mcpx servo, same kind of thing for the 130x. (skip to 2:45)
