Rakonheli 130x parts short reviews
  • Rakonheli 130x parts short reviews
    I have a pretty much all rakonheli 130x now, so have a pretty good idea of the useful parts and the parts that are not that good. I was going to post pics of each part but there're loads on HF.
    I was also testing my lipos for the 130x (arrived today ). As I only had the garden to fly in I was doing pretty much constant pitch pumps and 'smacky flips' which resulted in 13 crashes most inverted without throttle hold. No damage at all.
    Anyway here's what I think of the parts
    RKH blade grips
    No slop at all and look very strong. One of the most useful upgrades as the ball link snaps off very easily on the stock grips and the stock ones are £10.
    RKH head
    Don't know how useful this is but I've heard that in some crashes the stock head breaks - never happened to me though. If buying again I'd probably have gone for the lynx one as I don't really like the exposed feathering shaft
    Swash
    Completely pointless IMO - after 40 flights the bearing has just as much slop as the stock one and is able to move side to side on the main shaft.
    Xtreme solid main shaft
    Cheap amd definitely worth it - looks indestructible which can't be said for the stock one.
    RKH locking collar
    A metal collar is good as the stock breaks easily. The MH or lynx one looks better though
    RKH tail case
    I bought this because the stock bearings on the tail had pretty much given up. Looks nice but not sure of there was anything wrong with the stock part...
    RKH tail slider
    A metal tail slider is probably the second most useful upgrade after the head as in a lot of crashes the tail slider ball link breaks off (happened once to me).
    However RKH isn't the best option here as the tail slider pins can come out if you don't CA them in.
    RKH tail blade grips
    I found these terrible. Can't use KBDD blades, the screw head broke off inside the tail shaft and the bearings were notchy. I think the tail may have been better stock. Also yesterday I had one of the tail blades come out in flight (it snapped off at the root hole) which may or may not have been related to the grips.
    Metal A Gear
    Been great so far - loads of crashes all with no damage to any gears.
    A lot of these upgrades really are worth it as they make the heli far more crashable. However of buying again I would give the RKH swash and tail grips a miss.
    Hope this is somewhat helpful
    Stanley
    Sent from my GT-I9100 using Tapatalk 2
    Gaui X5 - Spartan Vortex
    Thanks for posting your experiences... I'm sure it helps those deciding what blingy bits they want.
    on the mCP X I found I had to go with some microheli bits and some rakon bits to end up with the heli I wanted. some of the parts from each were a bit hit and miss but between the two of them you could get some worthwhile upgrades lol.
    I just got some lynx parts in the post (main grips, hub, solid carbon main shaft) and I have to say - bloody brilliant. I'm really, really impressed with them. For me I think my 130X will become a mostly lynx bird as they bring out more stuff - the quality is just on another level compared to my RKH/microheli experiences.
    The only catch is I see KDE are starting to make parts for the 130X - and I do love myself a bit of KDE....
      I would have preferred lynx parts but was a bit impatient - maybe I'll change the tail grips if they make them.
      Did you get them from abroad or are they in the UK now?
        RKH tail fin very thin CF. Mine suffered damage in very first (light) crash. Nothing like as indestructible as stock plastic fin ...
          I got them direct from lynx, but fast-lad stocks the lynx stuff in the UK - I see they have some of the 130X stuff but not the blade grips yet. Should be soon I guess.
          I'm really interested to see what KDE are planning too though.
            Re: Rakonheli 130x parts short reviews
            Small update after another 50 -100 flights.
            I found out that my metal a gear was a bit too short so there is some up and down play on the main shaft. Apparently lynx are releasing some shims to fix this may give it a go
            The rakonheli head block has been really annoying not clamping hard enough onto the main shaft and therefore wobbling a bit if the screw isn't done up extremely tight. Despite red loctite the screw still manages to find a way to unscrew itself!
            The main grips and tail case have been great. Swash is also fine despite the side to side play. This may even not be the swash's fault as I think the solid main shaft may be a bit narrower than the stock one.
              great reports fella's
              many thanks
                I tried a different solid shaft and it made it all wobbly,Stan....stock one back on and its fine...the head block also tetered
                  I might pick up a lynx one from FLs as I'm going to have to order 600 bits anyway
                  The stock one flew great but it snapped in a crash.
                  Got 10 flights with it today files great apart from a shaky tail - bit annoying as I just replaced the tail servo might be mechanical.
