Another post on how good the 130X is. I'm still pretty much a noob to the helis and progressed quickly from Co-ax helis to a 120SR and after a couple of flights with the 120SR, I got the 130X. I was able to hover it in no time and I've started a bit of FFF. I bought mine off a mate and he had already upgraded the tail slider to a metal one (not sure if it's the Rakon one or not) and I have a few other upgraded parts coming.
Question though:- surely some of the gears are better staying as plastic, rather than metal? If you've had a bad crash and you have say a metal main gear, would this not potentially damage something else?
The only thing I've damaged so far is the plastic tail gear (the black one that sits on the main shaft itself).
Also, the Gens Ace batteries you all use... Are they the 25C model or a higher C rating?
I noticed on my last flight that the tail was vibrating side-to-side a little, so I think next on the shopping list will be one of those o-ring kits.
