Fuel magnet degradation
  • Fuel magnet degradation
    quick one guys, I heard somewherre that you have to leave fuel magnets sitting in fuel or they dissolve, is this true?
    TT Raptor G4 + Vbar
    I've heard the same ..and do.. and its been OK well over a year
    PGK
      Re: Fuel magnet degradation
      I believe that is true yes! My friend left his dry all the time and one day he was flying and his engine leaned up loads and blew!! What had happened was the fuel magnet had broken down and blocked his filter restricting fuel flow causing the engine to lean up!! This was after owning the fuel magnet for about 3 months!! Another friend uses them and has done for years with no issues BUT always leaves enough fuel in the tank to cover the fuel magnet!!
        There are many rumours and thought on this, some say do! Some say don't!, Personally I have had good results with either half filling the tank or completely filling the tank and expelling the exhaust gasses in the tank from the exhaust, this helps extend the life of the foam fuel magnet.
        Thanks!
        Rossco
        Equipment for Sale:
          mines a pumped engine so no real exhaust gases, ill leave fuel in it though just to be sure! cheers guys
          TT Raptor G4 + Vbar
            What are fuel magnets for?
            just made me think about the 5 I have on the diesel line in the range rover. I know it's different as the magnets are meant to improve economy of fuel and are external but being all electric I'm curious as to the purpose.
              totally different mate!
              its just a bit of foam really, it stops fuel starvation - the idea being that if the pickup is not in the fuel, theres enough soaked into the foam to "tide you over" until it touches fuel again.
              I heard those magnets on cars do nothing?
              TT Raptor G4 + Vbar
                Interesting.
                Thanks.
                I'm told that the magnets can improve efficiency but I really can't say.
                I know we have them for the gas pipes on boilers too. Meant to line up the fuel in such a way as to improve efficiency.
                I get 25.4 mpg using cruise control set at 79 mph and 27mpg without cruise?
                18 mpg in town lol but I knew that would be the case.
                It's also remapped for performance.
                  I have them fitted to my both my nitros and have found that YES you do need to keep them wet in fuel. Believe me, they break up and go like jelly if you don't! I have had to replaced two recently and there not cheap.
                    Im running them in 2 heli one pumped engine and the other muffler pressure.i just refuel after each flight and ive had no problems with either . But if you let them dry out they will break up and the exhaust gases will ruin them as well just fill the tank up after you fly snd all is good
                    360 RC Technologys (Align )
                    Optipower /Optifuel
                    3d-ireland.com
                      I gave up on the foam fuel magnets as no matter what I did they wold break up. Moved onto the lynx MOAS and that seemed to last a lot better, but to be fair I have stopped using nitro helis so not sure what the fuel magnets are like now
                        I'm using the Lynx magnets in both my nitros. I keep the tank totally full and nip off the exhaust line. I have seen them fall to pieces in heli's that have been left with a dry tank in storage.
                        SAB Goblin 700 Beastx
                        Align T Rex 700e Beastx
                        Mikado Logo 550sx Beastx
                        Futaba 8fg.. oooohh
                          Anyone using the Lynx MOAS had any problems with them, they seem a bit light when in the tank. I went for them because of the problems I'd read about with the OMI type then read about some issues with the Lynx ones
                            Both my 90's have fuel magnets always leave the tank half full to submerge the foam magnet and the pipe, been over a year with both, no problems at all
                              Just remove the foam, slide a small stainless nut on, replace foam. Works a charm
