Originally posted by Keratos
View Post
Wrapping the current battery carrier in heatshrink does not give you the same result as a welded pack as you are still dependent on spring pressure for the electrical contact.
A proper welded pack is not going to cost all that much and will give you a much better solution in the long-run.
There are good reasons why we use such packs and don't go trying to shrink-wrap a loose cell carrier as you seem to be proposing.
