700n OS105 fuel leak
    If it spits it out of the carb make sure the regulator is clean and the spring is in good condition, essentially the pressure in the tank is pushing it past the reg. Mine does it when it's been sitting for a while and it's a bit gummy. Clean the inside including the silicon diaphragm with IPA, make sure spring is in good condition and it'll be reet
      I had a similar symptom on my OS 91 with fuel coming out of the carb and going everywhere. Turns out it was to do with the regulator on the carb ( how the needle inside the regulator seats ).
      New regulator fixed the problem completely
        I have had the regulator apart, gave it a blow with the air line, it seems to working OK, from what I can tell.
        I'll have a look and see if the spring / needle can be purchased as a new regulator is £105!
        Oxy 2 - Spartan VX1n
        Trex 700XN - Spartan VX1n
        Trex 700N DTS - Spartan VX1n
        Logo 690SX - Spartan VX1e
        780L Top - VBar Neo
        2 x 700L Top - Spartan VX1n
        Logo 550SX - Spartan VX1n
        Jeti DS14 BK edition
        DX9
        Pheonix R/C
        AccuRC
        neXt
          The issue is, over time the needle stops seating properly, it may be possible to repair the seat with a small drill but I just replaced the regulator.
          I got mine from RCJapan at much less than the cost charged over here.
            Did you get stung with import charges?
            780L Top - VBar Neo
            DX9
            Pheonix R/C
            AccuRC
            neXt
              Cost around £75 all in including shipping, VAT and handling charge this end.
              Also none in stock in UK when I needed mine IIRC
                I also need to strip the regulator regularly when the fuel starts coming out the carb. Not replaced any parts yet.
                Yan
                XL Protos 380, XL Power Specter 700, Align 700Top Dom, Green & Black Vbar Controls.
                  Chris, it takes 10 minutes to clean regulator, don't go replacing it until you've done that at least and tried it
                    I taken it apart and blown it through with an air line, ill get some IPA try that.
                    780L Top - VBar Neo
                    DX9
                    Pheonix R/C
                    AccuRC
                    neXt
                    • #25
                      Over a period of months the nitro will get every where in the model, and I mean everywhere. A good session of backwards inverted will see it dripping out the canopy if it's a bit rich, and the 105 likes to be rich.
                      Invertix 400
                      Vortex 285
                      TBS Discovery Endurance
                      X4 II
                      Schluter Champion Longranger
                      G4 E720
                      G4 E720 Big AIR edition
                      Goblin Urukay super slow
                      Goblin 700 KSE Slow
                      Goblin 700 KSE Fast
                      Srimok Faifa
                      Spectra G
                      Synergy 766
                      http://mangled-rc.com/
