Good afternoon all,
After what appears to be a slight bend on a main shaft I have replaced it, however there are 2 alan bolt that screwed in to the (old) shaft from either side just below rotor grips, below those 2 bolts there is one that goes straight through with a nut on the end "jesus bolt" (technical term). The new shafts no longer have screw threads for the 2 alan bolts.. Does the shaft now take 2 "jesus bolts" with nuts on the end?
thanks
tom
thanks
tom
