Hi guys got to test fly the trex 600E on monday after work had a bit of tail wag that needed sorting with a bit more head speed & reduction of gyro gain but other than that it needed 2 clicks of forward cyclic & it hovered hands off. I ran my first pack down to 50 % capacity then flew the v2 SE for only my second time. What more can I say about the v2? It's an absolute gem of a model & I just know it's going to teach me loads about heli flying. Luckily Pete (Raptorite) turned up & put both models through a series of fast forward & backwards circuits just o check over my setup & he noticed on the 600 that coming out of the turn when backing off on the collective it rears it's nose quite a bit, is this the dreaded cyclic interaction?
When I did the geometry of the links I was carefull to get them all squared up etc but I did notice some roll forwards of the fly bar when going to full positive pitch I am thinking this will be adding forward cyclic as the pitch is fed in what can I do to sort this problem?
Martin
Martin
