First flights of trex 450 V2
  • First flights of trex 450 V2
    Hi All,
    Just had my first first on the Trex 450 V2. Wow!!!! Nice heli. So much difference to my original one
    I'm running a 12T pinion which I'm going to change for the 13T I think. Liven it up a bit. What batteris are you all using. I need to buy three?
    CHeers
    Matt
    Cheers Matt
    where did you get it from, and whats the setup? im thinking of getting one to compliment my 600...
      Revolution 2100 at £30.55 each you'd be mad not to
      Why pay more for something that won't last and gives the same or less performance.
      Sponsored by CSM, Optifuel
      Your RC Heli World
        Revo it is then. Whats the web address?
        Matt
        Cheers Matt
          Found then now. Out of stock
          Gutted
          Cheers Matt
            get three Evo 25's Matt from HK if you don't want to wait,
            DMHC = Nice place to fly!
            MyPhotoBucket
            mmm what shall I buy next
              Gutted
              www.aurorra.co.uk will have them next week. Spoke to him yesterday and the stock should arrive on Friday - but defo by Monday.
              Blade CX2 - With AR6100
                Cool nice one
                Cheers Matt
                  Jamiem,
                  I got mine from Mr Models. My setup is standard with HS65MG and 401 with 9650
                  Matt
                  Cheers Matt
                    Gotta be the Revos Matt
                      Chris did u have a pack go bad in flight ?
                      MyPhotoBucket
                        Jason
                        Yes i did,my Revolution 4800 that i said was not as good as expected failed totally during its 13th flight,,,spooky eh
                        Matt and several others saw it as it happened,motor just shut down and Lipo was dead
                        Its back with Aurorra now
                        Did another inverted landing undamaged ,
                        We connected it to the Balancepro charger and it showed an error and when connecting it to the heli the ESC does not beep,,,but when you connect a voltmeter to the main terminals it shows 25.2v
                        What we think has happened is that one of the balance leads connections has failed,,its a bit worrying though that if this is the case the DPM actually shuts the motor down,,,not a good idea really
                        Again this makes me feel justified in my comments about the Lipos early performance against some ridicule i received saying other peoples are OK so why is mine playing up,,,well its dead now so i suppose i was correct all along
                          are k cool thxs found your post now and have posted in there
                          your have to let us know what caused it to go bad, once u find out in the other post
                          MyPhotoBucket
                            Flew Geegar TREX 450 v2 today. I did try Raptorl50luvvers v2 a few weeks ago, but I was very nervous of crashing it so just hovered. However as it was Matts obviously it didn't matter as much. So I ventured out a bit with it and was gobsmacked how good it felt, really locked in, much less micro tendancies (as Ade puts it) than my SE. I am definitely getting one now.
                            Slow Mo Blade 550x
                              Actually it's exactly what the DPM should do, if a cell is below 2.8V it shuts down, it isn't to know that a connection is bad it's just trying to stop you damaging the cell by over discharging. You could just not plug the ESC through the DPM and it would still work.
                              Your RC Heli World
