The antena on the Futaba 7 Channel RX is as you all know is very long, so will the way I have put thease cause any problems??
2.4 Antena routing
I don't see why it should - but perform a good range check before flying to be sure.
It might be an idea to also, during the range check, have someone stood at the heli and rotate it on the spot to check that - from a distance - you have good reception.
Nice governor
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
Thanks for taking the time to reply mate! Yea, the govenor works really well. Will do the range checks as you recommend!!---------------------------------------------------
Trex 700n DFC.
Trex 700e TOP.
Trex 700e Pro.
Trex 600n DFC.
Vbar Controller.
The cynic in me says that the aerials will not be a problem.
It`s the system reseting it self to zero as well as everyone elses that will cause them problem
Long live JR/Spektrum
Align T-Rex 600n Pro (Now with 3GX)
Align T-Rex 500CF(Gone)
Align T-Rex 450 Pro
T-REX 250, had it since crimbo(bloody tail) want to smash it with a hammer
T-Rex 700......STUNNING (Thirsty)
(Now with 3GX)
No plank flyers were hurt whilst making this post
If you haven't seen the threads or information from Ripmax/BMFA/Futaba regarding this - basically, there can be a problem with the transmitters GUID (Globally Unique IDentifier) resetting itself to zero - when this happens, the transmitter is no longer bound to only your receiver - it is able to interfere with other FASST receivers in the vicinity.
You can take your Tx to your local model shop who will hopefully have a testing receiver available to check your Tx.
Apparently, switching the Tx on, and then off again fairly quickly stands a good chance of resetting the GUID. 5 seconds has been mooted as the safe timeframe to switch off after switching on for this to not happen.
| 3D Championship
I route my two Futaba 2.4GHz RX antennae at 90 degrees to each other through fuel tubing for grip at the front like this:Attached FilesT-Rex 600 Nitro Pro (Futaba BLS451s, GY611 + 9256)
T-Rex 500 ESP (Align DS510s, GY520 + 9257)
T-Rex 450 SE V2 (Hitec HS65MGs, GY401 + Robbe FS 61 BB)
T-Rex 150 (Stock)
Futaba 14SG + FF7 2.4GHz, Mode 3
