Hi Guys, I need some advice.
I put the engine back in my TREX the other night after fitting a new clutch (Thanks Baz).
When I had put the 4 (rear facing) bolts in position holding the engine to the mounts, I could move the engine up and down quite a lot (at least 1 mm.)
I didn't know whether to push it up and then do the bolts up or just let it sit in its bottom position with the bolts in and then tighten them.
I wondered what you guys did with the TREX.
This time I tightened the bolts up with the engine in mid position. All seems ok but I would like to know what others are doing.
Mark
Mark
