now i'm confused
  • now i'm confused
    just built a trex 700n LE with a flybarless head, now it flys realy nicely apart from the tail wag. I've set everything up on the gear to gear on my DX7 and set the tail to 48% well in hh it wagged at a medeum rate from side to side so today i went up bit by bit to 60% and the wag got smaller but increased in frequancy. Now i'm a newbee so don't start ****ing yourself but am i going the wrong way on the gain. have i gone from wag to hunting. or could it just be its new and the dampers need to settle in.
    I think i need a local club with heli flyers.
    me need a club to.......
    RAPTOR 60
    TREX 500 CF, FBL
    MSR-X
    JR XG7
    __________________________________________________ ______________________
    http://www.hdrcmc.co.uk/index.htm
      what electronics are you using and which fbl unit ? this will help determin your problem
        Need more info fella.. what FBL unit are you using?
        Eddie
        Velocity 90 FBL BeastX V3
        Trex 600 LE FBL BeastX V3
        Trex 500 EFL Pro BeastX V3
        Fusion 50 FBL
        VBar
        All powered by a DX8
          LOL great minds think alike
            How far out from the centre is the ball on the tail servo horn??
            And yes, flying at a club has many advantages
              Yep, need a bit more info .............But to hazzard a guess, i would say that your gain settings may need to be higher, many radios work with a range of 0-50% for rate mode and 50-100% for HH mode with 50% being zero gain. So for rate mode the smaller the figure the higher the gain and for HH the larger the figure the higher the gain.
              so to have a gain for HH at the gyro of say around 75% you would need to dial in about 87% on the radio. and for the equivalent gain in rate mode you'd need to dial in around 12%.
              If this is the case with your radio then your initial setting of 48% would give you next to no gain in rate mode and your 60% would only be about 20% in HH.
              Hope this makes sense
              VIC.
              JR DSX9
              TREX 600E
              Century GL450SE now an Align Airwolf
              Robbe schluter Jet ranger futura 111
              Planks.....Chris Foss Phase 6... Sebart Sebach 342 30E.......
              natures helicopters have the best HH gyros...... sigpic
                still confused
                i'm using the align 3g with the silicon mod. the senser is strapped down as well. the bit i'm struggling with is understanding the difference between a wag and hunting and what should be done once you define what its doing. am i right in thinking a wag is a slow left right oscalation which you'd increase the gain to eliminate and hunting is a fast oscilation that you'd decrease your gain for.
                i'm using a dx7 set up via the gear-gear chanel where i'm guessing 0-100% is the amount of gain and 50% is mid point. do i set the gyro gain in rate mode to start with.
                  Shouldn't have to set the gyro in rate mode. Using the gear channel, a figure of 40% would be a good starting point. I'm sure for the short time I had my 3g on, I had to drop it lower to stop oscillations in fast forward flight.
                  If you are still running your engine rich, this might show up as a wag on the tail.
                  Also, check everything is silky smooth on the tail, no loctite in any of the links on the pitch slider. It only takes a slight bind to cause issues.
                  Simon
                  Trex 700N & E
                  x 2
                    watcha buddy
                    checked the tail and cant find any stickyness. The engine has been leaned out and is running nice if a little rich but the head speed seems about right. i'll drop the gains and give that ago. still don't know the difference between a wag and hunting though
                      aaar-ha
                      may have found the issue. I took all the tail rotor apart today and the small links to the blade holders seemed a bit tight. I took them appart and they seem smoother now plus i used a few drops of silicon oil on the shanks of the screws before loctiting back together. we'll have to see what happens when i fly it next.
                        arrrrrrrrrrrrrrrrrrrrrrr
                        still no better, flys like a bag of shite. I think its time to return it to the shop who set it up and club the guy to death with it
