My 700LE has flown!
  • My 700LE has flown!
    After many attemps, and either work or weather got in the way, I finally got to fly my 700 this weekend. This is the first time I have flown a 90 size heli, and the first time with a nitro since my Shuttle ZX over 13-14 years ago!
    I'm happy to say 'WOW' it was just fantastic! I needed only 1 turn on a link to get the tracking spot-on, and everything else was perfect. The gyro needed no adjustment, and doing some fastish collective pumps, the tail held very firm.
    In total I did 5 flights, and the last 2 were on sunday morning when the wind had picked up alot compaired to the first 3 flights on saturday. The smoke trail was almost horizontal, and was much stronger than I would ever fly the 450 or 500 in. The heli just sat there, nice and stable, with very little corrections needed, and again the gyro was so good. I just held her across wind, and you could see the corrections the tail was doing in HH. (A bit different to the old Futaba gyro I had in the Shuttle with the motor in it wizzing away!)
    All in all, I'm well chuffed with it, and will be spending lots of money on 20% Optifuel this summer
    Here are a couple of pics of my build as well.
    Henseleit TDR V-Bar x2
    SAB Goblin 700 V-Bar
    T-Rex 700e DFC V-Bar
    Synergy N7 V-Bar OS105 HZ-R
    Synergy E7se V-Bar
    Synergy N5c FBL V-Bar
    Gaui NX7 V-Bar YS91 Tareq SRX
    T-Rex 550 E FBL V-Bar
    Gaui NX4 V-Bar
    Congratulations on your maiden Rob (and the other flights ).. Looks really nice and neat mate..
    Enjoy it and have a great time flying it.. I've flown my 90 this past weekend as well and the noise those 90 engines make is worth every penny that goes on the juice
    Avant Aurora|Trex 700LE
    Trex 600NSP|Outrage G5
    Beam E4|Twister Storm
    Trex 250|mSR|mCX|4#3B
    DX7
    |1 EGS!
      That is one very neat 700 Rob..
      Looks fantastic, hope you enjoy flying yours as much as I do mine..
        Agreed Tim Very neat installation, I particularly like the modified holder with the grommet and the wires passing that way.
        Nice one.
        TDR (in progress)
        SAB Goblin 700
        Vibe 90SG Vibe 500E
        Kalt Baron30
          Nice idea on the rx tray
          Might have to copy that idea as it looks so much neater, can hide away everything under there.
          Glad your enjoying yours
            Looks like a nice tidy build!
            Enjoy!
            Martin
              Nice one, looks awesome!
              x 3
                Thanks guys, the grommet was from a multi pack from Halfords. I also shortened the length of the elevator servo holder so that the push/pull rods are parallel with the side frames, thus square with the crank arm.
                I have a pair of Radix 710 FIA blades on route, as I,m not a stick banger (yet!)
                Synergy E7se V-Bar
                Gaui NX4 V-Bar
                  It looks lovely!!.. Just a quick question.. have you got the rubber grommets between the servo plates?
                  Eddie
                  Velocity 90 FBL BeastX V3
                  Trex 600 LE FBL BeastX V3
                  Trex 500 EFL Pro BeastX V3
                  Fusion 50 FBL
                  VBar
                  All powered by a DX8
                    Yes mate, the grommets are in there, and the screws are 'nipped' up enough to stop too much servo movement, but not squashing them solid.
                    Synergy E7se V-Bar
                    Gaui NX4 V-Bar
