700 tail grips
  • 700 tail grips
    who is using the 700le tail grips with the standard bolts.
    i have no high tensile bolts left and was just wondering if anyone else uses them on their tail grips
    MARK
    MCPX BRUSHLESS
    LOGO 400 V BAR
    T REX 550 V BAR
    T REX 700 LE
    JR DSX 12
    JR DSX 11 THE UGLY B*S***D
    im using them and have had no problems so far
    Avant mostro 700E
    Avant mostro 700 Nitro
    member of :
    South cheshire heliaddicts
      how many flights u had with them
      MARK
      MCPX BRUSHLESS
      LOGO 400 V BAR
      T REX 550 V BAR
      T REX 700 LE
      JR DSX 12
        I would have said the same thing untill this happened
        Not worth the risk
          i know about what happened to yours matt and i heard of it happening to a few others thats why i normally fit the high tensile bolts or use the quick uk tail.
          what have you got on yours now matt
          MARK
          MCPX BRUSHLESS
          LOGO 400 V BAR
          T REX 550 V BAR
          T REX 700 LE
          JR DSX 12
            Not worth the risk
            Noted.Cheers Matt
            Avant mostro 700E
            member of :
              I'm using the Quick UK grips now, quite a few gallons on them now and they are still as slop free and silky smooth as the day I fitted them
                4Dee had the actual output shaft snap on his 700G
                http://www.rcheliaddict.co.uk/gasser...on-kit-16.html
                  I have the Fastlad tail upgrade with extra bearing and longer bolts,but I still have slight movement when you move the tail grips..???
                  TREX 600 pro V-BAR
                  TREX 500 V-BAR
                  DFC
                  BLADE 130x
                  DX7
                  PHOENIX
                    Some movement is a none issue as when its turning at 8000 rpms it will be fine.
                    Brian
                    SPARTANRC Team pilot
                      ive now fitted the quick uk ones as i had a set here. cheers guys
                      MARK
                      MCPX BRUSHLESS
                      LOGO 400 V BAR
                      T REX 550 V BAR
                      T REX 700 LE
                      JR DSX 12
                        That's more worrying than the bolts shearing as you can easily upgrade the bolts to guard against them failing but I do't think it's possible to upgrade the output shaft is it?
                        Gaui Hurricane 425 FBL
                        Phoenix
                          Re: 700 tail grips
                          Not that I have seen but this is the first time I have heard of a failure like this
