9253/4 throttle servo
  • 9253/4 throttle servo
    does any 1 know if its ok to use either of the above for the throttle. have heard of a mate thats its not a good idea. any 1 know.
    Gaui x7 lush
    Gobbalin 500
    ALL ON SPEKKY GEAR
    Blade 130x2
    nano
    I am currently running a 9254 as my throttle servo and this replaced the 9253 that it used to use... I run it with a TJ Pro governor in digital high speed servo mode. Been working perfectly since 2004 (touch wood)
    Futaba 9CP & 10CG
      Will be fine
      x 3
        reason i asked, was on the other site hf, our fav guy on there has said its a bad idea to use with an align guv,
        Gaui x7 lush
        Gobbalin 500
        ALL ON SPEKKY GEAR
        Blade 130x2
        nano
          yep thats because its not a 6v servo... u need to use a stepdown on it Gaz
          Lee
          www.raptoruas.co.uk
          www.lee.rcha-uk.com
          www.gensace.de
            i am mate, have done around 15-20 flights so far not had a prob, just what someone told me
            Gaui x7 lush
            Gobbalin 500
            ALL ON SPEKKY GEAR
            Blade 130x2
            nano
              9254s are prone to vibrations shall we say... me personally i have vowed never to use one again after the one in my 600 goes (next on my list). Had too many fail now... would rather have an Align 620/650 now
              Lee
              www.raptoruas.co.uk
              www.lee.rcha-uk.com
              www.gensace.de
                I have had 2 fail on the tail but never on the throttle, I think this one has been going for about 2 years now having been in the Knight and now in the 700.
                Regards,
                Jason
                  Ive had 5 fail now (on the tail)... bloody ridiculous tbh. I wouldnt dare trust one even on me throttle and thats sayin something
                  Lee
                  www.raptoruas.co.uk
                  www.lee.rcha-uk.com
                  www.gensace.de
                    No need whatsoever to drop the voltage if its a regulated 6v, ive had a 9254 on the throttle of this and my last synergy for approx 2 years now with no problems at all, running off a flight tech regulator at 6v
                      but like everything in this hobby... go with what you think is right not what everyone else tells you to do. Everyones experiences are totally diffrent ive found in this fantastic hobby. What works for one person might not work for you.
                      Lee
                      www.raptoruas.co.uk
                      www.lee.rcha-uk.com
                      www.gensace.de
                        cheers guys for your comments, its a 9253 i am using, with an align reg. also if any 1 knows, i am building a 600 at the mo and using an sl720 with a 620 do you know what frame rate to set it to, origianally i was using the 720 with a 9254 so was set to 333fr
                        Gaui x7 lush
                        Gobbalin 500
                        ALL ON SPEKKY GEAR
                        Blade 130x2
                        nano
                          id imagine it would be the same Gaz as they very similar spec off the top of my head...
                          Lee
                          www.raptoruas.co.uk
                          www.lee.rcha-uk.com
                          www.gensace.de
                            thinking about it, i was using the servo in my vision with a 401 which run at 333 and never had a problem. should be fine then. lads
                            Gaui x7 lush
                            Gobbalin 500
                            ALL ON SPEKKY GEAR
                            Blade 130x2
                            nano
                              Is it almost ready for tommorow then Gaz?
                              Thanks, Chris
                              Avant Aurora
                              T-rex 700 LE - BeastX
                              T-rex 600 NSP
                              Member of ;
                              SCHA www.southcheshire.rcheliaddict.co.uk
                              BMFC http://byleymfc.webs.com/
