I had the exact same problem on my 600le last week,checked the usual suspects,all were fine.I discovered that the grub screw on the elevator arm was loose,letting it move from side to side on the control shaft causing the awful vibration on a negative descent.Grub screw tightened,heli flying great.
Trex 600 shakes
Like the sound of this going to check it now!Originally posted by trevorj View PostI had the exact same problem on my 600le last week,checked the usual suspects,all were fine.I discovered that the grub screw on the elevator arm was loose,letting it move from side to side on the control shaft causing the awful vibration on a negative descent.Grub screw tightened,heli flying great.Trex 550 v2 fbl
Trex 500 ESP fbl
Trex 450 se V2
Raptor 50 Titan
TT Raptor 30 V2 upgraded
Not quite the same, but we had one of our fliers with a rex that had SEVERE tracking problems, whatever we did they were just way out. Swapped them over with mine(got nitro smell on my leccie now, EUCGGH!
), and they were perfect. Turns out his blades-brand new out the box!!- were out of balance. Maybe try and swap your blades with someone first? Just a shot in the dark really.....
Flying T-rex 600ESP!!
Already tried 3 sets in the hope of solving - cheers!Originally posted by Airwolfie View PostNot quite the same, but we had one of our fliers with a rex that had SEVERE tracking problems, whatever we did they were just way out. Swapped them over with mine(got nitro smell on my leccie now, EUCGGH!
), and they were perfect. Turns out his blades-brand new out the box!!- were out of balance. Maybe try and swap your blades with someone first? Just a shot in the dark really.....Trex 550 v2 fbl
Trex 500 ESP fbl
Trex 450 se V2
Raptor 50 Titan
Re: Trex 600 shakes
Happy to help out James. Like the sound of the missing grub screw. What's the latest?Originally posted by James B
Bloody good idea that! Raymondo, if you are watching this, let's make like Quentin Tarantino next week!
RayLogo 550sx Spirit System
Goblin 500 Spirit System
Compass Atom 500 Fly barred
Compass Warp 360 FBL
Some of them fpv quad racing things
And an EGS. Many thanks
mine came loose in the boom and i didnt actually notice it till i broke itChris 'CHUNK' Newby
ALIGN-TREX.CO.UK team pilot
LYNX team pilot
SPARTAN team pilot
Dx18
yeah me too - maybe if we get our choppers out together (haha) and compare all the bits around and attached to the head to see what wiggles on mine, and what wiggles on yours, maybe we will be able to see whats missing/looseOriginally posted by madgooner99 View PostHappy to help out James. Like the sound of the missing grub screw. What's the latest?
Ray
the manual only shows one grub screw in the elevator bar.......which was still in place....Trex 550 v2 fbl
Trex 500 ESP fbl
Trex 450 se V2
Raptor 50 Titan
bearing for the torque tube tail? I have a belt drive - I prob should have mentioned that earlierOriginally posted by smokingtommy View Postthe bearing in the boom would make it shake if its come loose
cheers!Trex 550 v2 fbl
Trex 500 ESP fbl
Trex 450 se V2
Raptor 50 Titan
When spooling up, when can you start to notice the shake? (full chat etc)
I know you arent really meant to, but id be inclined to remove the boom/tail section and blades then spool it up. If that doesnt do anything, I would refit it then take the headblock and swash assembly off and spool it up to see if that makes a difference.
x 3
I'm in from 3 pm all week if you want to pop over to 'compare choppers' mateOriginally posted by James B View Postyeah me too - maybe if we get our choppers out together (haha) and compare all the bits around and attached to the head to see what wiggles on mine, and what wiggles on yours, maybe we will be able to see whats missing/loose
Good idea - not sure if this would show it up, but worth a try. When I get a video up this will make more sense, as its not a violent shake, but more of a constant movement of the whole heli, up/down/side to sideOriginally posted by sacko View PostWhen spooling up, when can you start to notice the shake? (full chat etc)
I know you arent really meant to, but id be inclined to remove the boom/tail section and blades then spool it up. If that doesnt do anything, I would refit it then take the headblock and swash assembly off and spool it up to see if that makes a difference.Trex 550 v2 fbl
Trex 500 ESP fbl
Trex 450 se V2
Raptor 50 Titan
