alloy starter block
  • alloy starter block
    What a difference the alloy starting block has made on my 600n,its just soooooo quiet now...worth doing,the plastic one wasnt holding the bearings tight and was getting a bad noise,alomost like when the engine bearings are going
    Cheers Nick
    does the Le have it as standard?
    Did you change the bearings too?
    If so did you have to get them saperate
    Cheers Paul
    Citizen #42
      Hi Paul,no,its plastic,but its new so ok at the mo but will deffo replace if it when i get some play in it
      I did replace the bearings too,but for the money align really should throw in the bearings with the block
        Did you glue the bearings in the bearing block?
        Member of Mk Heli Club
          Hi Andy,no...they fit like a glove...should they be glued?
            I was just thinking if the bearing started to turn in the plastic housing for any reason it would very quickly wear the plastic. In your original post you said they didn't fit very well.
            In the metal housing use some bearing fit loctite or the Align green.
              ive noticed some noise coming from one of my 600s and thought it was coming from the clutch block,changed the bearings out and its still there,a bit quieter maybe so i might try a metal block next time im flush
              Avant mostro 700E
              Avant mostro 700 Nitro
              member of :
              South cheshire heliaddicts
                Exactly what i went through Tony,thats why i replaced it
                Its dead quiet now
                  No they didnt andy,im guessing the starter i used didnt help,rubber cup type with wand,always had a wobble no matter how well you had it fitted...im gonna get one from quick uk tommorrow,one that bolts onto the shaft
