does anyone have any suggestions on how to keep my flybar level while checking for interactions on my trex 600?
flybar locking tool?
Originally posted by tonystevens View Postdoes anyone have any suggestions on how to keep my flybar level while checking for interactions on my trex 600?
You could use a trex blade caddie. It has a hole for a paddle at the correct height for it to be level
yes this works while checking elevator interactions as the flybar is laying along the tail, but not for aileronOriginally posted by youngdave View PostYou could use a trex blade caddie. It has a hole for a paddle at the correct height for it to be levelAvant mostro 700E
Avant mostro 700 Nitro
member of :
South cheshire heliaddicts
thats it ,couldnt figure out where to put the allen key.thanks martinOriginally posted by rcslopesurfer View Postit's easier than that guys.
I believe you can use a 5mm or 6mm allen key to lock it in place.
Slide it in where the fly bar cage meets the mast block to lock it in place.
Martin
Avant mostro 700E
member of :
I reckon the swash leveller works fine.Originally posted by SadSack View PostYes, it's th@ tw@ Scallyb@...
That's a neat idea! I've been using the allen key and my blue CNC head is getting a little scratched as a result.Originally posted by mickeybling View Posthi. i use a simple wooden clothes peg one pushed down each side off head block ,witch acts as a wedge and holds flybar in place.
I use my own designed flybar locking tool (not patented yet!!
) - it allows me to change from one heli to another easily. The aluminium piece is araldited to the paper clip and it fits on the flybar paddle and not on the bar. Although it can be easily adapted to fit the bar. Should not take more than 20 min to make it.
CheersAttached FilesLast edited by Hangar-7; 28-08-2009, 10:39 AM.
