Ideal headspead for hovering manouvers?
    Originally posted by Ponteflyer View Post
    Disc,
    I've made a note for the weekend on the expo %ages I'll give them a go
    What about dual rates? do I need to use them? I don't like the idea of flicking another switch really
    Shaun
    no dual rates
    set idle up 1 at 30%
    idle up 2 50%
    so you can flick between them both if you don't like one jump to the other idle mode
    Mark
    www.uavaerialservices.co.uk
    BNUCs - Operations certified
    CAA - Permit for Aerial Work
      Originally posted by Disc View Post
      no dual rates
      idle up 2 50%
      Bloody good idea
      Shaun Senior
      Spectrum Promotions (embroidery and printing)
      www.spectrumpromotions.co.uk
      E-mail: Shaun@spectrumpromotions.co.uk
        Actually for the 'B' Test
        Set up the helicopter:
        Paddles heavier than normal to smooth it out make it less twitchy
        Head speed adjust to slightly lower so not 2000 but say 1800 should be good
        Pitch Curve Now for the 'B' you can get away with -6 0 +9 I'd recommend you copy idle up 1 then make idle up 2 to -6 0 +9 The -6 means you won't drop quickly in any move, It makes it easier to handle unless you like -9 of course!
        Expo try to get used to 50% (Futaba thats -50 and spektrum is +50)
        Then fly it on idle up 2 if you don't like it switch to idle up 1 and fly as normal
        Mark
          I have my negative at -10, -6 makes sense though
          I have a free evening Wednesday if the weather isn't bad I'll try this then to get a feel for some serious stuff at the weekend
          Shaun Senior
            Actually, I'd dial in the expo gradually 'til you get used to it.
            Starting with 50% will feel as though you have no control over the heli and will need huge stick movements to control the cyclic and then you will over correct!
            Dial in gradually to a point you are comfortable with.
            T-Rex 500CF - 5245MG - Skookum 360 - DS760/9257 - Rotortech 430 - Custom Canopy
            T-Rex 600N Pro - 9451 - ATG - DS760/8900G - OS50 - FunTech - Rotortech 3D 600 - Custom Canopy
            T-Rex 700N - BLS451 - ATG - DS760/8900G - OS91SZ Pumped - Hatori SB18 - Rotortech 3D 710 - V2 Custom Canopy
            Member of Norfolk Model Helicopter Club
              for the B test i didn't change a thing on the heli
              practise the moves with the model set to how you are used to flying it
              if you don't like how it flys make small adjustments
              and the main reason i didn't change a thing was
              i got told i was doing the B from the chief examiner that i fly with
              although i had been practising for the B adding the various moves into my flight pattern and i was reading the bmfa handbook whenever i had the odd spare minute or two with nothing else to do
              good luck with the practise and the B
              on the 600 the grey dampers will stop in nodding at the lower head speed
              when i had mine i used one grey and one black in each side
              and i took my B with an eight year old sceadu
              Hirobo Turbulence D3
              1/4 scale Vario Bell 47 G3
              1/3 scale Vario R22
              2012 LHC Scale Cup Judge
