600 & DX7 all set up
  • 600 & DX7 all set up
    Hi guys
    Just set-up the 600 with my "new" DX7. It went really well. First thing I did after binding was get all the servos going the right way. It needed absolutely zero sub-trim to get the servos to 90! Result!
    Following that I pulled the head off and used the cheapo swash levelling tool to get it all level. I couldn't use an allen key this time as the top of the swash plate is higher than the linkage balls, so I cut down and old wire coat hanger and this worked a treat.
    I did find that, whilst it was level at mid stick, it was a little out at top and bottom. The DX7 travel adjust took care of this so now I'm level at bottom, middle and top stick positions.
    I've set my gyro gain to 65%. Will go hover in the week if time permits.
    Martin
    Nice one Martin. Hopefully should be a smooth flight when you get it out next.
    Tonight Matthew..I am going to be.. Nitroman
    Trex 600NSP
    Blade MSR
    Futaba 10C
    Very proud owner of an EGS and Platinum Gold Star
      Nice one Martin
      I've just set up your DX6i with my Trex 450, swapped the trims for the new ones and it all works great. Sold mine to my mate as yours felt better
      Phil OB3
      Trex 450SE v2
      Walkera 4#3b
      DX6i
      Phoenix
      http://stratfordgliding.co.uk/
      ...and proud owner of THREE!
        Cool! Glad all is well Phil.
        I never changed the trims cos I found that, with a little downward pressure on the rudder trim, it worked just fine.
        Martin
          I guess I just couldn't help fettling
          Phil OB3
          Trex 450SE v2
          Walkera 4#3b
          DX6i
          Phoenix
