Ok the Hughes is "flying" again and I've fitted 500 size tail blades to help the tail but if anything its much worse! I've tried using a throttle curve to keep the revs low and equally tried medium and high curves and all show the same result in that the heli just piros anti-clockwise as if the tail just cant counter the torque even with the larger blades. before it would hold for a few moments then skip about 45 degrees anti clockwise, hold and then skip again. At the moment though it is just piroing wildly.
The giro (3gx) is adjusting the right way in testing and the tail responds to the stick input correctly when not turning. I'm using an align 520 on the tail.
any further thoughts?
