450 augusta ESC problem...help please
  • 450 augusta ESC problem...help please
    Hi
    I have a trex 450 pro V2, with a stock 35amp esc, 3 blade rotor head, 2200mah lipo's, K-bar, AR7000 & sat, with x2 servos running retracts and also a lighting kit installed.
    When I test flew the 'pod & boom' it was fine after a few annoying issues were resolved.
    I tried to fly it a few weeks ago, but the pinion stripped off the motor shaft, I have now replaced that pinion and 'grinded' a flat spot on the shaft to stop the pinion from slipping. however when I connect the battery and do pre flight checks all servo's seem to jump a lot, and don't respond correctly when I give cyclic or collective input, it's a bit intermittent so to speak.
    Also I noticed today whilst testing that the ESC gets really hot, I felt the heat through the CF frame, and thought mmmmm, that's a bit warm! and it was.
    Am I overloading this esc with all the extra bits? and that's what's causing the heat up? and can this also affect the cyclic and collective inputs by causing the servos to jump around etc.. ie: with all the extra bits installed can the esc not provide enough power to the servo's to actually fly the heli?
    any advice is appreciated.
    Andy
    Blade 200 SRX
    Blade 450 3D in a MD500 fues
    Trex 450 pro in a Augusta 109 Fues (wip)
    Gaui x5 Formula
    Gaui X5 FES (wip)
    DX8
    RF6 flight sim
    Sounds like you need an external bec like the castle creations 10amp, the align bec is only rated to 3amp.
    Cheshire Hell-E-Cats best in Static May 2013
    Charmouth - Best In Show April 2013
    Kyosho concept 30SR Hughes 300
    Kyosho concept 60SR II Jet Ranger
    Mini Titan Agusta A109,Tow Cobra and Bell Huey
    Futaba 9ZHP WCII
