what size is scale
  • what size is scale
    hello silly question about scale
    I know about the scales 130 450 600 etc.
    but how big or small are 1/3rd 1/8th 1/9th scales etc. as I am at the moment im thinking on bidding on a 1970/80s 1/9th scale Morley Bell 47 G
    and I was trying to work out what 1/9th scale was
    any help appreciated
    DX6I
    blade 450x
    Morley Bell 47g RNLI colours 1/9th scale
    Morley bell 47g in a pearl purple and white
    Heli sizes of 130-450-600is a size that came about for electric helicopters and often can be an indicator of blade length. IC powered helicopters were sized on their engine size of .30 .50 .90 etc
    Scale is completely different. Scale means that it is a model in proportion to it's real full size counterpart. A scale helicpter is a model resembling a real helicopter in the form of a body kit or fuselage over a pod & boom or built and engineered from scratch. Many pre bought fuselages are also known as funscale where the proportions aren't particularly representative but still look the part to the untrained eye.
    Thus a 1/3rd scale helicopter will be 1/3 of th size of the real helicopter it is based on. So the Morley you are intereted in is 1/9th the size of a real Bell 47G.
    Serious scale enthisiasts will scratch build complete airframes and propulsion systems and even theie fuselages. See the post with the fella scratch building his Wessex. Pod & boom heli kits most of us use are bolt together some parts from the manufacturer. Scale builders are engineers and true modellers.
    Thunder Tiger Raptor E820 - KDE 700XF 395 - YEP 180A - Futaba HV 272/274SV - Bavarian Demon 3SX - SAB 800mm - 6.6V LiFE
    Blade 450X - Stock AR7200 Beast X
    DX8 - AR8000 + Sat & TM1000 Telemetry
      thank you for your quick reply and sorting out my confusion on this matter
      the one I after is listed on E-bay item No is 161441411050
      I am hoping to win this auction and then start the strip down and rebuild in the new year
      fingers crossed
      DX6I
      blade 450x
        Thats roughly a 30size nitro. As woodsta says its 1/9th real size. all its specs are in one of the pictures.Looks like it uses 550 main blades (1143 disc dia.)
          As already mentioned its a bit difficult to say since a 1/6 Blackhawk would be a lot larger than a 1/6 md500 for example.
          Personally I'd just go by the obvious - check disc size of real Heli, divide by scale factor (eg by 9 for your 1:9), and then find the size of Heli that is designed around that sort of blade size.
            the morley bell 47g is a 40 class heli that runs 515/520 main blades
            it is roughly the same size as a 30 class pod and boom or a trex 550e in modern money
            Hirobo Turbulence D3
            1/4 scale Vario Bell 47 G3
            1/3 scale Vario R22
            2012 LHC Scale Cup Judge
              i also know the other morley 47 listed
              when it was in flying condition
              shown here competing in the LHC Scale cup
              1/3 scale Vario R22
                thanks to all
                I won the auction for the bell cant wait to get my hands on it
                DX6I
                blade 450x
                  my 60 class century Seaking is 1/12th scale its going on a raptor 50e if that helps
                  Raptor 50 v2
                  Raptor 50 titan se
                  Raptor X50n to go in sea king fuz
                  Raptor 90
                  dsx9 mk2
                  600 size Sea king being built
                  Bo-105 in red bull colours waitng to be built
                    Well done Goldslinger,this hobby needs more Scale.
                    I'm trying to get the other one on ebay.
                    I'm also after a much larger Hirobo or Vario Bell 47G.
                    Hirobo Lama with Electric Conversion
                    GraupnerMZ24 PRO
                      the other one on ebay has had a few mods since it was built in 2006/7 from a box of bits with a new canopy,bubble and dummy fuel tanks from the LHC/Morley Shuttle,Raptor Bell 47 scale kit
                      it still has the century swift motor in it and it should have a 75A trex 600 esc
                      the clutch is still used in the heli
                      and it is using a hirobo shuttle rotor head that Jim Morley approved of when he saw it
                      it is one of 4 morley 47's that was awarded the morley scale cup
                      the last time the scale cup was awarded
                      here it is flying at the mk heli club fly-in
                      1/3 scale Vario R22
