Nitro Engine Issue
  • Nitro Engine Issue
    Ive got a small .15 nitro engine im having issues tuning.
    The engine was running fine a week ago, but came to start it today and it still ticks over nicely, however when i get to about 1/3 to 1/2 stick it starts spluttering and cuts out..
    i have tried the following :
    • resetting both needles
    • changing the fuel lines
    • new glow plug
    • cleaning the carb
    • checked the engine bolts (also had a look at the piston and liner etc)
    • fresh fuel
    Still no joy
    Any ideas ?
    TT Raptor 50, TT Raptor 30, TT Raptor E550
    Bambucopter Bluebird Tricopter
    Bambucopter Crab Quad
    Modified X650 quad with Ardupilot Mega 2.5 and GPS (currently for Sale)
    HK 250, Blade MSR, Hubsan x 4
    A couple of planks.
    Air leak between the carb and main block? have you replaced the "o" ring?
      it seemed to be a snug fit and tightened up well.
      may have to remove again and have another look.
      A couple of planks.
        If the seal is ok try running a richer setting or leaner and see how it performs.
        The Fleet
        Trex 450 Pro on Brain 2
        Mini Titan super Cobra ah1
        Alien 550 Quad.3DR Pixhawk
        Futaba 7C 8FGS 14SG
        Specktrum DX6i
          Thanks - given that a go and still no joy
          A couple of planks.
            Air leak between back cover and crankcase?
            Trev
              Check your clunk itself. Ive had one rust up, which reduced flow. Not enough to stop it starting, but wouldnt hold WOT.
              Logo 600 3D --- Vortex Vx1n
              JR Forza 700 --- Vortex Vx1e
              And the proud wearer of one
                Might be a long shot but I've seen this before at the club. Turned out to be the rear bearing. Swapped it for a new one. Cured the problem right away.
                David
                SAB Goblin 700 Beastx
                Align T Rex 700e Beastx
                Mikado Logo 550sx Beastx
                Futaba 8fg.. oooohh
                  If it's ok at idle.... and dies on throttle up would be mid / high needle to rich. Try leaning 2 clicks at a time. Do you get a lot of smoke and any unburnt fuel from the exhaust...sorry don't know how much experience you have with engines, not trying to teach you to suck eggs but that is where I would start.
                  And a DX8 too
