MicrobeastX and Futaba 12fg
  • MicrobeastX and Futaba 12fg
    Hi guys, I realise it's probably a bit of a stupid question but...
    Does the BeastX Microbeast work with the Futaba 12fg using a standard 2.4 reciever? if so is there any specific things I should look out for
    Heli will be a T-Rex 600 Nitro FBL.
    Thanks in advance!
    Alex
    Just use the 617FS receiver if you're not fussed about S-Bus
    7ch FASST Futaba P-R617FS/2-4G - 7ch Rx 2.4GHz - Transmitters and Recievers Receivers - ALIGN-TREX.co.uk
    or the 6203SB if you fancy the S-Bus version.
    6-18ch FASST S-Bus (HV) Futaba R6203SB Receiver - Transmitters and Recievers Receivers - ALIGN-TREX.co.uk
    I would recommend this one as it's literally a couple of wires going in to it. Keeps the wiring down and is ideal for FBL setups. Just make sure you follow the instructions in the Bx on using an S-Bus receiver (Page 18 of the V3 manual).
    Hope that helps!
    SAB
    Trex 500 FBL /
    Beast X
    Futaba 8FG
    Proud Owner of 2 EGS Awards
      Works fine Alex just plug and play ! What's happened with the jets ?
      Glenn
      logo 600se
      700 N dfc
      700 dfc
        I have mine running on. 9c super, don't see how it's going to be any different as its a standard receiver. Watch out to plug the wires in the correct slots, I had one of my gyro wires connected in the wrong one in my 500' took me ages to find it was the problem, Ian.
        [/SIGPIC]Goblin 700 vbar blueline, spektrum Hv servos|Goblin 570 Red/Yellow, mini vbar pro, BK's|Goblin 500 red, mini vbar pro, scorpion 4020 1100kv, jive 100+,BK's |Goblin 380, xnova 2820, mini vbar, yge 90, quick connect|Trex 450 pro 7200bx & RJX fbl head|130x|ncpx|DX9| BMFA Member|
          Thanks for the replies guys!, as I'm using the 12fg I can't use the S.bus system from looking on Futaba's site.
          Glenn, Still doing the jets and picking up a new 50ccer next week but I fancy a new venture and I've fancied getting into Heli's for a while
          Thanks again guys!
          Alex
