Talking Ball'Links!
  • Talking Ball'Links!
    I have at last rebuit my 700 £££s later, and av just spotted that i have had my Beast X set in "j" cyclic controle loop, light showing puple not blue @ 6 degrees, flys fine though, iam sure i've seen a thred talking about this (can't fined it now) I am running the servo horns on the inside hole, aile and ele levers are stock 700n, so if i want to get more resolution between cyclic servos and swash this could be arrived at by using shorter balls, i.e ele lever ones, on the bottom swash ring rather than the longer stock ones. i am thinking that this would give a little more servo travel to get to the pitch required and so give me the magic blue light at 6 degrees
    Am i barking up the wrong tree? Woof Woof!
    GAUI X7 Beast X V3 (a nice bit of fish!)
    Trex600n Fbl ys56sr BeastX V3
    Trex500Fbl AR7200BX
    Trex500 Apache x4bld BeastX. Trex 600E HIND mil x5bld BeastX
    DX7se
    I think quite a few people have the same problem mine was like this and it flys fine,
    The geezer in the setup vid thats kicking about also said it shouldnt be a prob as long as the beastx knows where 6 degrees is
    Gaza07
    Trex 500esp 6s Beast-X V3
    Trex 600esp 12s Beast-X V3
    A few Multi Rotors
      Yep c'n it bud my beasty700 is on the table in front of me so just going to see how much differance it will make in set up, i'm getting red at 6 now and 6.5-7 when showing blue can't be far out, may be a while!
      Noop not good balleyes strike swash at full throw worth a try spose
      Trex500Fbl AR7200BX
      DX7se
        I'm not barking mad, thay allways say that! think i may have sorted it by swaping the 'A' arm (nitro) with 'A'arm lever 'E' (two holes) what do you think crack'd it or crack'd up!
        Trex500Fbl AR7200BX
        DX7se
