Setting up the new Spektrum 2.4
    Similarly with the tail servo: mounting it on the other side of the boom means the blades have to go through that first.
    Don't forget that if you touch any of this you'll have to recheck your tail/ gyro settings.
    Neil H: Certified compatible.
      Seems like you've a few adjustments to make.
      Martin
        Hi all,
        Well i was happy until i posted this lmao just changed the belt direction and reversed the channel strangley anough it hovered ok today in the garden with it all back to front (Maybe this is a new skill i got)
        Thanks lads for the tips maybe answer me a bit quicker next time back to the drawing board Hehehehehe i like you all really
        Lee
        T-REX 450 SE (CDE)
        Spektrum DX7 Transmitter
        Align GP780 Head Lock Gyro
        AR7000 Dual Link Reciever
        Turnigy 3S 30C 2200 Mah 11.1v LIPO
        Align Brushless motor 430L
        Savox Digital servos SH0257
        Tail Servo Align DS520
        Its Only Time The Ground Will Get You
          I guess that, if the rotor was spinning the wrong way and the gyro/servo was reversed, I can see no reason why it wouldn't hold in the hover. However, if put under pressure, things may have gone horribly wrong.
          Martin
