Ok, let me explain.
After a few weekends flights and simulator sessions if i go out for a flight then i notic the tail twitching. It gives a twitch randomly causing a flutter. The reason why i think this it DX6i battery related is because if i change them then its fine again.
Now before i know you come back with the battery response let me just say that currently the battery status is reading 5.9/6.0. Now i think this is more than enough given people are reporting warnings at 4.3
Any suggestions ?, no reason to think its a faulty unit and always kept and looked after in a silver case when not in use.
Receiver is a ar6000 non satellite, all running in a trex450 sport and happens regardless of the 3s pack voltage. Odd, i've tried recabling and management as well.
Thanks for any eye opening - not even sure this would be the correct thread.
Ian
Ian
