Thats hell of a wag, check all the mechanicals again and make sure nothing is binding
power loss
That sounds like a restriction or dirt in the main jet!Originally posted by Adrian View PostWell i turned the needle to +3 turns out and bingo we have power.
Have you cleaned it all out, thoroughly? If all else fails, blow it through with WD-40!
I've known slight burrs on the fuel input nipples to cause silicone shavings from the fuel tubing to float up into the jets before now!
PetePete
Had a go at cleaning it,no obvious bits ect to effect it....still got the wagging thing going on thoughOriginally posted by pchristy View PostThat sounds like a restriction or dirt in the main jet!
gonna knock it on the head tonight b4 next door complains about nitro smoke choking them
thats the only thing i can think
