Can never get it to loop quick like the sim?
  • Can never get it to loop quick like the sim?
    Hi lads,
    Was out last night practicing the FF and some more looping while in idle up anyway all seemed very well and the settup seems spot on. I am now wondering on the sim the slower i go the quicker it loops to the point were im still it will just flip over instant without any drop within reason, so last night for real this never seems the case im dropping 10 to 15 meteres before i finish the loop?? Its not a problem im going heigher anough but is there a way of doing the loop tighter or is it the diffrerence bewteen sim and real life and you will always get a drop?
    Any feedback and advice will be greatly recieved
    T-REX 450 SE (CDE)
    Spektrum DX7 Transmitter
    Align GP780 Head Lock Gyro
    AR7000 Dual Link Reciever
    Turnigy 3S 30C 2200 Mah 11.1v LIPO
    Align Brushless motor 430L
    Savox Digital servos SH0257
    Tail Servo Align DS520
    Its Only Time The Ground Will Get You
    As you enter the loop you want to be giving more positive pitch then easing off the pitch to mid stick at the top (0) pitch, if you want wider loops put some negative in at the top and ease off the elevator, as your coming out the loop give more elevator and feed the positive pitch back in! hope that helps
    Cheers Paul
    Avant Aurora fbl
    Synergy N9 ys91srs
      Thanks paul, i think im doing what im supose to be and giving 0 pitch etc maybe its just the timing is out for me it feels like its going ok but hey supose more practice is needed, was wondering if the helis response was the issue and mybe tweak some settings thats all.
      Lee
      T-REX 450 SE (CDE)
        Not 100% sure if this is the correct answer or not but I learnt about this from the sim watching the training videos.
        I practiced last night and it worked ok for me.
        If you are talking about still loops then this will work, on the start of your loop in idle up bring the throttle back to mid stick and you will get a quicker loop, as long as you increase throttle just as the flip is finishing then you won't get any drop of height.
        I am sure that someone will chip in if I am wrong (appols if I am)
        lee
        Crashing is in my blood, were can I get a transfusion
        You can never have to many batts
        Flasher 500
        Trex 450v2
        Dx6i
        Purfleet Model Helicopter Club member
          Remember that the sim model is set-up perfectly and you are relaxed when using it. For most of us the real flying tends to being snatched from pucker factor and there is a loss of smoothness.
          It may be worth rechecking your stick/pitch relationship mechanically since most sims use non-ccpm outputs and the PC does the calculaion whereas your TX will vary a bit. It depends on how high end your tx/rx are as to how easy these things are displayed on it's screen and then there is still a difference in effective response since as soon as you use a tx it's pots start to wear (reality)
          Ultimately so long as you are getting the move safely it's usually a matter of settling yourself calmly and repeating until you get that timing and judgement for each model/tx combo. The wizz kids have the reflexes to adjust as they go where (reality again) most of us make the commitmment and pray
          .just look at an F1 drivers ability to cope with unpredicatble behaviours and incidents...
          PGK
            Thanks for your time, great input will take onboard your advice cheers, thinking about it now i dont think i hit the Elevator anough at the end of the loop.
            Lee
            T-REX 450 SE (CDE)
              Originally posted by clubb699 View Post
              Hi lads,
              Hi just thinking would it help to spin the heli in loop quicker is your head speed at right/capable RPM mayve try increase it more not to much and try that. I done it on my Raptor increased head spped more it was more responsive. Maybe im wrong but no harm in trying
              Thanks guys for wicked weekend
              That was some mental flying guys !! !
              Compass Knight 50
              , OS Hyper engine
              Spektrum DX7 + AR7000 RX
                Aint that the truth
