When I very first started I was advised - rightly or wrongly - to set hover (+6)at centre stick and have no more than about -4 at bottom stick.
This was to avoid putting in too much negative pitch in a panic moment when throttling back hard and making the whole matter worse. Also, to give a longer range of pitch & throttle stick movement around hover.
Now, I have gotten used to -4(P1) 6(P3) and 10(P5) but this does not give the clean -10,0,+10 curve most people use and it means a strange throttle curve to give more power lower down to hold the hover, so the whole thing looks a bit strange.
I think the best thing - now those panics are over, I hope - is to set my helis up in the more usual linear pitch / throttle curves and re-learn the 'feel' of hover at 3/4 stick. I think the whole heli would be smoother.
I pretty well reckon what you are all going to say, but anyone else been through this process?
Any input gratefully accepted.
David
David
