Quick question - when the mixing arms are attached to the blade grips rather than the flybar carrier, which rod do you adjust for blade tracking? A or B or other?
Tracking Question
strangly steve that is almost the same set up as the blade 400!!! i adjust rod "A" rod "B" is not adjustable on the blade!
Im guessing they wont or shouldnt need adjusting enough for that to happen. Especially since the washout mixing arms to flybar cage rods are'nt adjustable by the looks of it.Originally posted by The Manager View PostOk, thanks so far.
But when you adjust either of these rods, the mixing arm shifts off it's neutral middle position and then looks out of place.
LeeLast edited by Made2Fade; 27-12-2008, 01:41 PM.
That's kinda what I was thinking. Doesn't the N9 have a similar setup?Originally posted by Droid View PostIf you want to keep everything in line you'll have to adjust both, longer or shorter.
Fortunately tho, maiden flight this afternoon and the tracking was puuuuuurfect, so no adjustments required.JR Vibe Fifty fb (YS56)
