I am going to make a cable from the receiver pack to power the system on a nitro, i will be using a futaba rx so can i run power from the 2s lipo battery straight to the fbl unit or is it wise to make a Y harness and go to the futaba rx aswell splitting the power? Also could i use a spectrum backplate sensor with mounting on a (105hz-r) as i am using futaba tx/rx?
Cheers.
Cheers.
